Skip to content
View in the app
'Orange Clunker Car' - MPC General Lee Build - FINISHED
Featured Replies
I recently started working on an MPC General Lee build.  I know the Revell '69 Charger kit is a much better kit, in fact I have a couple of those.  However I wanted to see if I can make the MPC kit just a little bit nicer and more accurate.
The kit I'm building is the most resent issue by Round 2.  I have an original issue from back when the Dukes Of Hazzard was first on the air with the incorrect rear window.  I was happy that the newest issue comes with the correct tunnel back rear window.  Well when I opened the box the tunnel back rear window didn't quite look right.  The molding is too wide and the shape looked off.  I took out one of my Revell '69 Charger kits and compared the two side by side.  The Revell kit appears to be correct so it's a pretty good reference.  The MPC Charger's rear window is too small and incorrectly shaped.  It's basically a rectangle instead of having an arc on the top.
I started by removing the molding and adding sheet styrene to the inside so I would have enough plastic to re-shape it. I used a sanding stick and a file to enlarge the window and re-shape it to more closely match the Revell Charger's rear window.  Since I wanted to use the clear plastic (glass) that comes with the MPC kit the window is slightly narrower than the Revell kit's window but has the basic shape.  In addition I sanded down the rear deck and trunk lid area to level out some of the slope.  It was angled too much and is now closer to what it should be.
Here are some pictures showing the progress.  The 1st picture shows the comparison between the Revell '69 Charger and the MPC Charger's rear window.  The Revell Charger is on the left side and the MPC Charger is on the right side.  The rest of the pictures show the modified rear window of the MPC Charger.
36162835186_a39a39bf1c_o.jpgIMG_5848 Small by Michael Scarola, on Flickr
36204387845_6ca758b43a_o.jpgIMG_5887 Small by Michael Scarola, on Flickr
36037109842_b2a54edfdb_o.jpgIMG_5890 Small by Michael Scarola, on Flickr
36069642831_0b9d2edf8a_o.jpgIMG_6089 Small by Michael Scarola, on Flickr
36037140802_a854b24ee0_o.jpgIMG_6046 Small by Michael Scarola, on Flickr
Edited by Boss JD Hogg
  • Replies 51
  • Views 23k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Roth Potter
    Roth Potter
    Nice job! I bought two MPC kits myself this summer although I´m not much of a model builder so I probably won´t do this to mine. I got the Revell one as well. I should compare the two to see what ve
  • Mark B / Scooter Davenport
    Wow- really nice work!  I'll be following this!   M
  • Boss JD Hogg
    Boss JD Hogg
    Here's some more progress on the General Lee.   I filled in the space behind the license plate below the rear bumper.  It's strange how this part of the body is split.  I put some sheet styr
  • Author
Thanks guys!  I'm having a lot of fun on this one.
Here's some more progress pictures.  I picked up a bunch of parts from a Revell '69 Charger kit on E-bay and started incorporating them into this build.  I started modifying the MPC kit's chassis by cutting the front frame rails off and installing the Revell kit's parts.  I also installed the rear wheel wells and the rear piece of the frame on the back of the chassis.
I sanded down the rough texture in the engine compartment and installed the Revell kit's firewall and scratch built the two shock towers.
35811582700_e656295dc6_o.jpgIMG_5881 Small by Michael Scarola, on Flickr
35399746433_1d3f322198_o.jpgIMG_5885 Small by Michael Scarola, on Flickr
35399763783_2f6c503814_o.jpgIMG_5916 Small by Michael Scarola, on Flickr
36069764041_2ef3048885_o.jpgIMG_5944 Small by Michael Scarola, on Flickr
35811661110_f760d93c9a_o.jpgIMG_6037 Small by Michael Scarola, on Flickr
36069772651_1780572678_o.jpgIMG_6038 Small by Michael Scarola, on Flickr
35399836223_285427e29d_o.jpgIMG_6039 Small by Michael Scarola, on Flickr
36163088646_28e7df26af_o.jpgIMG_6057 Small by Michael Scarola, on Flickr
  • Author
I filled in the space behind the license plate below the rear bumper.  It's strange how this part of the body is split.  I put some sheet styrene behind as well to close it all off and strengthen this area of the body.  I also sanded the putty in the engine compartment.
The hood that comes with this MPC kit is actually a 1970 Charger hood.  MPC did put out a Charger 500 kit that was based on the Dukes kit that had a correct 1969 hood.  I was able to get my hands on one for this build.  The picture with the two hoods shows the correct (yellow)1969 hood on the left and the (white) 1970 hood that came with this kit on the right.
I'm using the exhaust system from the Revell Charger which is more accurate than what came with the MPC Charger. I had to make the area that goes over the rear axle shorter to fit the MPC chassis by cutting out a small section.  The last picture has the chassis with the exhaust system and rear end axle and springs in place.  These are parts from the Revell Charger kit.
35368423614_bd17732d1d_o.jpgIMG_6056 Small by Michael Scarola, on Flickr
35400103993_5d93f121ef_o.jpgIMG_6080 Small by Michael Scarola, on Flickr
35400115013_de82afc884_o.jpgIMG_6094 Small by Michael Scarola, on Flickr
36069908641_6811d00e6d_o.jpgIMG_6066 Small by Michael Scarola, on Flickr
36163251246_dca5db3385_o.jpgIMG_6100 Small by Michael Scarola, on Flickr
36163256586_fec612d78c_o.jpgIMG_6105 Small by Michael Scarola, on Flickr
  • Author
Here's a small update.  The MPC kit comes with a full roll cage.  In the pilot episode and at other times the General Lee was seen with a full roll cage but for the most part in the series a single loop roll bar was mainly used so I scratch built the roll bar.
The interior is very crude and only indicates the location of most of the details such as the arm rests so I scratch built them.  I think the interior looks a bit better with the arm rests.
The seats in the kit have molded in seat belts which don't have very sharp detail.  I removed the seat belts and scribed in the appropriate seams in the seats.  I forgot to take a picture with the molded in seat belts but the picture below shows how they look now.
The mounting hole in the dash board for the steering wheel was too far to the right so I filled it in and re-drilled it a bit to the left.
I did get some more work and details done but have to take some more pictures.  I'll post some more soon.
36069979801_733a046697_o.jpgIMG_6111 Small by Michael Scarola, on Flickr
36069994561_23fb082c3c_o.jpgIMG_6112 Small by Michael Scarola, on Flickr
36070008601_d27e2ce17d_o.jpgIMG_6134 Small by Michael Scarola, on Flickr
36070013981_ea1391dda2_o.jpgIMG_6131 Small by Michael Scarola, on Flickr
35400340463_ff185cba01_o.jpgIMG_6124 Small by Michael Scarola, on Flickr
  • Author
This build is loosely based on the Georgia cars.  LEE 3 had padding on the roll bar which made it look thicker.  Mine will be painted tan to match the interior as if it has padding.  Since it's white plastic it is looking slightly thicker than it does in person.
This picture below shows the roll bar with the padding.
36037580162_e594962798_o.jpgdoh by Michael Scarola, on Flickr
  • 3 months later...
  • Author
It's been a while but here is an update.  I started painting the wheels. I made pedals and an automatic shifter for the interior.  I'll be using a heater under the dash board from a Revell 69 Charger.  The engine is a 440 with an automatic like used on the show cars.  This model comes with a Hemi engine that was never used on the show.  The head rest on the front seat is a set from a Revell 69 Charger.
I started painting the chassis.  I painted it mostly like it would be painted at the factory with gray primer in the middle and the body color overspray.  I painted the engine compartment and inner front wheel wells as if the car was painted with the front end off.
I painted the body with Testors Custom Lacquer System Hugger Orange and applied the decals.  The decals represent how the car looked in the early Georgia episodes.  I also painted the headliner inside the body.
36205093115_d1e5602a24_o.jpgIMG_6206 Small by Michael Scarola, on Flickr
36070149391_b87a986127_o.jpgIMG_6195 Small by Michael Scarola, on Flickr
35812130420_a9e11820b2_o.jpgIMG_6238 Small by Michael Scarola, on Flickr
36205118985_cf1245d47c_o.jpgIMG_6225 Small by Michael Scarola, on Flickr
35812175090_75520f5a60_o.jpgIMG_6244 Small by Michael Scarola, on Flickr
36205129445_27efae9c92_o.jpgIMG_6174 Small by Michael Scarola, on Flickr
36037857322_69802563d4_o.jpgIMG_7191 Small by Michael Scarola, on Flickr
35368755784_53275b48cc_o.jpgIMG_7218 Small by Michael Scarola, on Flickr
35368776124_89057b01b5_o.jpgIMG_7212 Small by Michael Scarola, on Flickr
35368778424_6ccbc2a890_o.jpgIMG_7214 Small by Michael Scarola, on Flickr
36163684076_a39249b617_o.jpgIMG_7216 Small by Michael Scarola, on Flickr
35368784724_cb89c55050_o.jpgIMG_7215 Small by Michael Scarola, on Flickr
  • Author
Thanks Roger!  The early Georgia episodes are my favorite and this is my favorite look for the General Lee.  I like the earlier darker tan interior more than the later light colored interior.
Here is some more work I did on the interior.  I painted the interior seats and door panels in Tamiya acrylic XF-59 Desert Yellow which is actually a dark tan color that's a good match to the saddle tan interiors in the 69 Chargers.  The dash board, rear speaker deck and the kick panels in front of the doors panels are painted a darker color.  It's a mix of Testors acrylic leather and dark tan.  These areas were a darker color than the seats and door panels in 69 Chargers.
The carpeting is made with Champagne colored embossing powder I got from Michael craft store.  I painted on some Testors acrylic clear and poured the powder on top.  It gives the look of carpeting.
The center console is painted to look like wood grain although it isn't showing up to well in the pictures.  I painted the inset in the dash Testors acrylic silver and then painted Tamiya acrylic flat black on top.  The Tamiya acrylic paint is easily removed with Windex where as the Testors acrylic paint will not be removed with Windex.  I used a toothpick slightly moistened with Windex to remove the black paint around the gauges and to pick out the details of the radio and some buttons.  The red button on the left was painted after this was done.  It was sealed with Testors acrylic clear.
The trim around the center console, door handles and the straight molding towards the top of the door panels is done with Bare Metal Foil.  The window roller handles, round Charger emblem(in the top of the door panels), and trim around the shifter area are done with Testors acrylic silver paint.
I also added some Bare Metal Foil trim on the head rests but haven't taken any pictures yet.
36205376515_d0d1ac280e_o.jpgIMG_7239 Small by Michael Scarola, on Flickr
36070480331_fbcab4d828_o.jpgIMG_7253 Small by Michael Scarola, on Flickr
36163971576_02dfeffd73_o.jpgIMG_7259 Small by Michael Scarola, on Flickr
Maybe somebody already mentioned this, but this is a Blooper picture! The passenger door is standing open! ( The General's doors were " Supposed" to be welded shut!
16 hours ago, Roth Potter said:
Well, there's also no 01 on the door. :) This picture is from before the show even started so not everything is right yet.
WOW!! I can't believe I didn't notice that!!! Color me pink with embarrassment!
  • Author
That's a cool early picture.  You have to take a second look to notice the open door the missing 01.
Here's an update.  I painted the black on the tail light panel and sprayed the clear lacquer on the body.  In a week or so I'll polish the clear.
Today I made a couple of adjustments to the stance(ride height) and took some pictures with the wheels and tires on one side.  It's propped up on the other side.
35369058504_0d27bebb12_o.jpgIMG_7265 Small by Michael Scarola, on Flickr
35400910583_45d26c4858_o.jpgIMG_7269 Small by Michael Scarola, on Flickr
35812507230_deecedae78_o.jpgIMG_7297 Small by Michael Scarola, on Flickr
36038103252_8be2d17256_o.jpgIMG_7295 Small by Michael Scarola, on Flickr
36038184112_71916e6e8d_o.jpgIMG_7288 Small by Michael Scarola, on Flickr
35400968963_9c67a1175d_o.jpgIMG_7291 Small by Michael Scarola, on Flickr
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
