DixieDavenport Posted July 21, 2018 Posted July 21, 2018 First, I have the WORST vehicle luck and have since I was 15 years old. I have a 1991 F-150 pickup that SHOULD be easier to work on. It has ran great for a year. I had surgery in Feb 18 and was off work until June 4th. June 5th the good ole pickup decided that I should not go to work!! Well, I took sons car and every since my sons car has been my way to get to work. The truck WAS starting faithfully every evening / afternoon. We had done process of elimination and found it is NOT a firing, moisture or lack of gas issue by changing the electrical box under the dash just below the steering wheel. Then the Distributor cap, rotary button and fuel relay. We now know it is flooding itself. The front fuel pump has not worked since we have had the vehicle about a year now, but on the rear pump, when you turn the key (as if to roll up a window or listen to music) the fuel pump cuts on and does NOT cut off. IF it starts it is running rich loading up bucking as if trying to flood out you can smell the gas at the exhaust. The shop has had it 2 wks and it has started twice and they "don't have a clue". I have purchased a fuel pressure regulator but don't have it on yet since truck is still at the shop. Can anyone tell me if I'm on the right track? Give me suggestions of things to try -- I have a 1992 in the yard I can try parts from but really need to figure out a way to get it started or wait until at least Monday to get it towed home. I've ran through this with all the guys at the fire department and the fuel pressure regulator makes about as much sense as anything. I don't want to take to a Ford place and pay 800 for a 20 part. All suggestions and ideas welcome!!! I really need my ride running ASAP. Thanks to all my Hazzard cousins -- DixieDavenport CooterNnancylou 1 Quote
HossC Posted July 21, 2018 Posted July 21, 2018 I'm no mechanic, and always turn to Google to find out if a problem is easy enough to fix myself, or if I need to visit my equivalent of Cooter! I found a thread with a similar-sounding problem here. The fuel pressure regulator is mentioned as a possibility. Roth Potter and DixieDavenport 2 Quote
Hobie Hartkins Posted July 21, 2018 Posted July 21, 2018 Yes, this is what I would try first too. You might just want to replace the fuel pump altogether. Let us know how it comes out for you! Good luck Dixie! Quote
RogerDuke Posted July 24, 2018 Posted July 24, 2018 If your shop has had it 2 weeks and hasn't figured it out it's above my head. It sure is good to hear from you Dixie. I've missed you. Quote
DixieDavenport Posted July 25, 2018 Author Posted July 25, 2018 Thanks Hoss, Hobie and Roger!!!! Ok I got the fuel pressure regulator, my fire Chief is gonna borrow a trailer from the Asst. Chief (it won't fit on his) and go get it Thursday. Once here, my son who declares himself a YouTube Mechanic thinks he can do it. If not, the Chief and his Girlfriends dad (who looked at it before we figured it was flooding) are close by. As for being over ya'lls heads, NO! It wasn't an easy fix -- EX. Not just a water pump, a plug wire etc..... it is a problem they had to figure out so "to save me money,.... the guy doesn't want to 'guess'!" I'm like give me a GOOD Guess I'll bring you the part off my 92! But since the regulator has a diaphragm I figure of plastic or rubber I figure in the 92 that hasn't been on the road in a couple year (which MAY have the same issue) I'd buy a new one - got it at O'Reilly's for 19.99! I will be SO happy and yet to a degree very pissed if this is what has caused it not to run since JUNE 5th! Yes, I miss you all TOOO!!! Brandy Lou and I have been tossing around a story so may post it once it is done. Thanks Ya'll!!! I'll let ya know when I know more! Quote
RogerDuke Posted July 26, 2018 Posted July 26, 2018 Thanks for the update Dixie. I sure hope you log in more often. I'm always surprised at how often folks miss the simple things when fixing stuff. (My first reaction was that it might be the fuel filter) but clearly this is more complicated. Where is the fuel pressure regulator located? Quote
Spike Posted August 16, 2018 Posted August 16, 2018 If a shop has had it for 2 weeks and can't figure out what's wrong it's time to find a new mechanic. Finding a decent honest mechanic these days isn't easy. The world could sure use a few more Cooter's in it instead of some of the scum that call themselves mechanics. Hobie Hartkins, JHDuke and Boss JD Hogg 2 1 Quote
Roth Potter Posted August 16, 2018 Posted August 16, 2018 I didn't wanna say it, but I do agree with Spike. Quote
Boss JD Hogg Posted August 18, 2018 Posted August 18, 2018 It could be something simple. I'm surprised the mechanic had it so long and couldn't figure it out. Quote
CooterNnancylou Posted October 26, 2019 Posted October 26, 2019 On 7/20/2018 at 5:09 PM, DixieDavenport said: First, I have the WORST vehicle luck and have since I was 15 years old. I have a 1991 F-150 pickup that SHOULD be easier to work on. It has ran great for a year. I had surgery in Feb 18 and was off work until June 4th. June 5th the good ole pickup decided that I should not go to work!! Well, I took sons car and every since my sons car has been my way to get to work. The truck WAS starting faithfully every evening / afternoon. We had done process of elimination and found it is NOT a firing, moisture or lack of gas issue by changing the electrical box under the dash just below the steering wheel. Then the Distributor cap, rotary button and fuel relay. We now know it is flooding itself. The front fuel pump has not worked since we have had the vehicle about a year now, but on the rear pump, when you turn the key (as if to roll up a window or listen to music) the fuel pump cuts on and does NOT cut off. IF it starts it is running rich loading up bucking as if trying to flood out you can smell the gas at the exhaust. The shop has had it 2 wks and it has started twice and they "don't have a clue". I have purchased a fuel pressure regulator but don't have it on yet since truck is still at the shop. Can anyone tell me if I'm on the right track? Give me suggestions of things to try -- I have a 1992 in the yard I can try parts from but really need to figure out a way to get it started or wait until at least Monday to get it towed home. I've ran through this with all the guys at the fire department and the fuel pressure regulator makes about as much sense as anything. I don't want to take to a Ford place and pay 800 for a 20 part. All suggestions and ideas welcome!!! I really need my ride running ASAP. Thanks to all my Hazzard cousins -- DixieDavenport Don't we all wish cooter was real !! Quote
Hobie Hartkins Posted October 28, 2019 Posted October 28, 2019 On 10/26/2019 at 3:01 PM, CooterNnancylou said: Don't we all wish cooter was real !! Cooter Yes!...Ben Jones...No! ( I've got his book and he's a leftist....I'm being nice....) Quote
RogerDuke Posted October 29, 2019 Posted October 29, 2019 Hey Hobie have you ever heard this before?.....If you go to the doctor and say "Doc, it hurts when I do this".....what's the doctor say?...."Don't do that". What I'm trying to say is this: don't pay attention to the actors.....they are not perfect people and can potentially hurt or disappoint you. (well, maybe not Sonny. He's a genuine Hazzard County kinda guy). Pay attention to the show because it makes you feel great every time. Hobie Hartkins 1 Quote
Hobie Hartkins Posted October 29, 2019 Posted October 29, 2019 True Roger. Cooter is a great guy! Quote
RogerDuke Posted October 30, 2019 Posted October 30, 2019 6 hours ago, Hobie Harkins said: True Roger. Cooter is a great guy! I think about him anytime my car breaks down and usually think about him when I see my mechanic. I sure wish Cooter lived around here. I suppose if I called him the next time my car broke down he's say it was to far to drive the wrecker from Georgia to Lake Erie. Hobie Hartkins 1 Quote
