Boss JD Hogg Posted September 18, 2017 Report Share Posted September 18, 2017 (edited) I started working on another General Lee model. This is the 1/25 scale MPC Snap Kit General Lee. I started by re-shaping the rear window. It's basically a rectangle in the kit so I made it a bit larger and rounded at the top and also changed the angle to be a bit more steep. I added missing window trim under the side windows and made the rear wheel openings slightly smaller in the rear. The body is painted 1975 Corvette Flame Red which was the color most used on the General Lee(s) in the TV show. The paint is from Gravity Colors. The decals represent the early Georgia car which is my favorite look. In a few days I'll spray the clear coat on the body. I worked on the interior a bit. I scratch built arm rests, pedals, window rollers, center console, head rests automatic shifter and a roll bar. This kit comes with a stick shift but the General Lee was always shown on screen with an automatic. I also modified the transmission on the chassis to resemble a 727 Torqueflite automatic. The interior had an armrest molded into the center console which I removed. I also added a strip of molding along the upper part of the door panels. Much like the MPC glue kit General Lee, the dashboard sat too low and level. I raised it up and angled it a bit. The interior tub sat to low and too far forward when it was attached to the inside of the body. I removed the mounting tabs and filed down the sides so it fits up to the top of the doors and moved back a bit. I had to then move the dashboard forward. The grill inserts in the kit are for a later year Charger, much like the MPC glue kit. I scratch built new grill inserts using some ribbed styrene sheet. The push bar is scratch built to resemble the early style push bar. I'll get the parts in primer and start painting them. Thanks for looking in! IMG_8605 Small by Michael Scarola, on FlickrIMG_8606 Small by Michael Scarola, on FlickrIMG_8609 Small by Michael Scarola, on FlickrIMG_8633 Small by Michael Scarola, on FlickrIMG_8660 Small by Michael Scarola, on FlickrIMG_8678 Small by Michael Scarola, on FlickIMG_8683 Small by Michael Scarola, on FlickrIMG_8692 B 30 C 10 Small by Michael Scarola, on FlickrIMG_8694 Small by Michael Scarola, on FlickrIMG_8696 Small by Michael Scarola, on FlickrIMG_8699 Small by Michael Scarola, on FlickrIMG_8701 Small by Michael Scarola, on FlickrIMG_8711 Small by Michael Scarola, on FlickrIMG_8712 Small by Michael Scarola, on FlickrIMG_8717 Small by Michael Scarola, on FlickrIMG_8723 Small by Michael Scarola, on FlickrIMG_8735 Small by Michael Scarola, on Flickr Edited December 20, 2017 by Boss JD Hogg Hobie Hartkins and MoonRunner-01 2 Quote Link to comment Share on other sites More sharing options...
RogerDuke Posted September 20, 2017 Report Share Posted September 20, 2017 Great start! Quote Link to comment Share on other sites More sharing options...
Boss JD Hogg Posted September 20, 2017 Author Report Share Posted September 20, 2017 Thanks Roger! I'll post more updates soon. Quote Link to comment Share on other sites More sharing options...
Boss JD Hogg Posted October 30, 2017 Author Report Share Posted October 30, 2017 Here's another update! I painted the interior and used embossing powder for the carpeting. The interior is painted Tamiya XF-59 Desert Yellow. The dashboard and speaker tray are painted Testors Acryl Leather with a few drops of white added. The center console is painted to look like wood although it doesn't show too well in the pictures. I painted Testors Acryl Leather over Testors Flat White with some Radone Tan added. I used BMF(Bare Metal Foil) on the door handles and trim.The chassis is done. Since it's a snap kit with molded in exhaust and drivetrain, I just painted it Testors Acryl Aircraft Interior Black. The Exhaust and drive shaft are brush painted with Citadel Leadbelcher. The engine oil pan is brush painted Testors International Orange and the transmission is Tamiya XF-16 Flat Aluminum. The gas tank was airbrushed with Tamiya XF-56 Metallic Grey.The body was clear coated with Gunze Mr. Super Clear and polished.I have to apply BMF to the moldings and install the windows. IMG_8799 Small by Michael Scarola, on Flickr IMG_8805 Small by Michael Scarola, on Flickr IMG_8808 Small by Michael Scarola, on Flickr IMG_8810 Small by Michael Scarola, on Flickr IMG_8815 Small by Michael Scarola, on Flickr IMG_8816 Small by Michael Scarola, on Flickr IMG_8821 Small by Michael Scarola, on Flickr IMG_8822 Small by Michael Scarola, on Flickr IMG_8824 Small by Michael Scarola, on Flickr IMG_8825 Small by Michael Scarola, on Flickr IMG_8828 Small by Michael Scarola, on Flickr Hobie Hartkins and Flint Duke 2 Quote Link to comment Share on other sites More sharing options...
RogerDuke Posted October 31, 2017 Report Share Posted October 31, 2017 You are a real artist! I am a big fan of those two smaller flags just in front of the trunk. I've always wondered why they didn't keep those. Quote Link to comment Share on other sites More sharing options...
HossC Posted October 31, 2017 Report Share Posted October 31, 2017 I'm guessing that when you're having to prepare roughly two cars for every show, any time-saving shortcuts help, so leave the small flags off. Great work on the model, BTW. I was expecting a snap kit to be far less detailed, but that doesn't seem to stop you adding those details in. Quote Link to comment Share on other sites More sharing options...
Boss JD Hogg Posted October 31, 2017 Author Report Share Posted October 31, 2017 (edited) Thanks Roger and Hoss for the kind words! I read somewhere that they removed the 2 smaller flags to save time since they weren't seen all the time. The early Georgia episode Generals are my favorite look for the car so I like to include them on my builds. I'm not as crazy about how the General Lee had the light beige interior and the wider/flatter push bar in the later seasons so I tend to stick with the earlier look. This snap kit is a new tooled kit from MPC but it's largely based on the original General Lee glue kit. It does have a correct 1969 hood. The original glue kit has a 1970 hood. I added the same details to the interior that I added when I build the glue kit last year and scratch built the push bar too. The General Lee parts(push bar, roll bar, CB radio, decals...) that come in the kit aren't too accurate so I made them and used decals a friend had made for me. I didn't use the Vector wheels that came in this kit either. I'm not sure why they didn't include the same wheels from the glue kit, which are far more accurate. This kit's wheels are flatter then they should be. I used a set of Vectors from an AMT 1969 Riviera kit that look more accurate. I have to put the foil on the moldings and install the windows and I can put it all together. Thanks again for looking in and the nice comments! Edited October 31, 2017 by Boss JD Hogg Quote Link to comment Share on other sites More sharing options...
Hobie Hartkins Posted November 7, 2017 Report Share Posted November 7, 2017 Your cars are awesome! You really are good at making the General look good! Boss JD Hogg 1 Quote Link to comment Share on other sites More sharing options...
Boss JD Hogg Posted November 21, 2017 Author Report Share Posted November 21, 2017 On November 6, 2017 at 11:51 PM, Hobie Harkins said: Your cars are awesome! You really are good at making the General look good! Thanks, I really appreciate the nice words! I really love the General and enjoy putting in the time. Hobie Hartkins 1 Quote Link to comment Share on other sites More sharing options...
RogerDuke Posted November 22, 2017 Report Share Posted November 22, 2017 And we enjoy your posts and your friendship! Boss JD Hogg 1 Quote Link to comment Share on other sites More sharing options...
Roth Potter Posted November 23, 2017 Report Share Posted November 23, 2017 As always, great job on that model! On 31-10-2017 at 2:31 AM, Boss JD Hogg said: The original glue kit has a 1970 hood. I didn't know there was a difference on the hood between those years. What is different? Quote Link to comment Share on other sites More sharing options...
Boss JD Hogg Posted November 24, 2017 Author Report Share Posted November 24, 2017 On November 21, 2017 at 11:45 PM, RogerDuke said: And we enjoy your posts and your friendship! Hey Thanks! I enjoy talking with everyone here on this great forum. Quote Link to comment Share on other sites More sharing options...
Boss JD Hogg Posted November 24, 2017 Author Report Share Posted November 24, 2017 (edited) 6 hours ago, Roth Potter said: As always, great job on that model! I didn't know there was a difference on the hood between those years. What is different? Here's a picture showing the MPC General Lee's(1970) hood on the right side in white plastic and an MPC 1969 Charger hood in yellow plastic. In 1968 and 1969 the 2 scoops in the hood were smaller. In 1970 the 2 scoops were wider and differently shaped. IMG_6094 Small by Michael Scarola, on Flickr Edited November 24, 2017 by Boss JD Hogg Quote Link to comment Share on other sites More sharing options...
Roth Potter Posted November 24, 2017 Report Share Posted November 24, 2017 My mind is blown! I always though something was off on 70s Chargers. Guess I know what it is now. I have an MPC kit as well. Bought it 3 years ago in a know museum in the UK. It seems to be a glue kit though as I just checked it out. It 100% has the hood thats on the right side of your picture! I got the Police car as well as a Revell Charger. Can definitely see the difference in hood in the Revell and MPC chargers too. Quote Link to comment Share on other sites More sharing options...
Boss JD Hogg Posted November 24, 2017 Author Report Share Posted November 24, 2017 (edited) From what I heard when MPC originally released the 1/25 General Lee they couldn't find the correct 1969 hood and interior bucket. It was released with a 1970 hood and a stock car interior bucket. When MPC released the Charger 500 kit they found the correct 1969 hood. The 1969 hood tooling was misplaced again so the General Lee kept the 1970 hood. 1969Charger500 by Michael Scarola, on Flickr When I built my MPC glue kit General Lee I located a 1969 hood from a Charger 500. Here's my MPC glue kit General Lee I built last year with the 1969 hood and correct interior.IMG_7579 Small by Michael Scarola, on Flickr Edited November 24, 2017 by Boss JD Hogg Roth Potter and Hobie Hartkins 2 Quote Link to comment Share on other sites More sharing options...
RogerDuke Posted November 27, 2017 Report Share Posted November 27, 2017 If it wasn't sitting on a wooden table I would have thought it was a real car! Fantastic! Quote Link to comment Share on other sites More sharing options...
Roth Potter Posted November 27, 2017 Report Share Posted November 27, 2017 ^ What this man said. Quote Link to comment Share on other sites More sharing options...
Boss JD Hogg Posted November 28, 2017 Author Report Share Posted November 28, 2017 (edited) Thanks Roger and Roth! Edited November 28, 2017 by Boss JD Hogg Quote Link to comment Share on other sites More sharing options...
Boss JD Hogg Posted December 20, 2017 Author Report Share Posted December 20, 2017 I finished the General Lee. Here are some pictures. IMG_9080 Small by Michael Scarola, on Flickr IMG_9082 Small by Michael Scarola, on Flickr IMG_9068 Small by Michael Scarola, on Flickr IMG_9084 Small by Michael Scarola, on Flickr IMG_9089 Small by Michael Scarola, on Flickr IMG_9072 Small by Michael Scarola, on Flickr IMG_9073 Small by Michael Scarola, on Flickr IMG_9077 Small by Michael Scarola, on Flickr IMG_9078 Small by Michael Scarola, on Flickr IMG_9090 Small by Michael Scarola, on Flickr IMG_9093 Small by Michael Scarola, on Flickr IMG_9095 Small by Michael Scarola, on Flickr Spike 1 Quote Link to comment Share on other sites More sharing options...
RogerDuke Posted December 21, 2017 Report Share Posted December 21, 2017 (edited) Another masterpiece!!!!! Is that antenna removable or were some of those pictures taken before it was glued on? Edited December 21, 2017 by RogerDuke Boss JD Hogg 1 Quote Link to comment Share on other sites More sharing options...
Boss JD Hogg Posted December 21, 2017 Author Report Share Posted December 21, 2017 Thanks Roger! The antenna is removable using magnets. I installed a magnet under the trunk. Quote Link to comment Share on other sites More sharing options...
Boss JD Hogg Posted December 21, 2017 Author Report Share Posted December 21, 2017 (edited) Here are some pictures I took with both General Lees I built. The lighter orange GL is this one I just finished and the darker orange GL is the one I built last year. This new one is painted 1975 Corvette Flame Red which was the main color used on the beauty cars on the show. The last one I built is Chevrolet Hugger Orange which is a darker, more red, looking orange. IMG_9098 Small by Michael Scarola, on Flickr IMG_9100 Small by Michael Scarola, on Flickr IMG_9105 Small by Michael Scarola, on Flickr Edited December 21, 2017 by Boss JD Hogg Spike 1 Quote Link to comment Share on other sites More sharing options...
RogerDuke Posted December 22, 2017 Report Share Posted December 22, 2017 You could do an episode of "Double Dukes" since they had two. "Dukes Meet Cale Yarborough" had three. I probably wouldn't have even noticed the color difference if you wouldn't have mentioned it. I probably would have thought it was just the lighting. Once again, excellent works of art! Boss JD Hogg 1 Quote Link to comment Share on other sites More sharing options...
Boss JD Hogg Posted December 22, 2017 Author Report Share Posted December 22, 2017 (edited) Thanks again Roger! "Dukes Meet Cale Yarborough" is one of my favorite episodes. I remember back when I first saw it I thought the white Charger was so cool and then the 3 General Lees at the end was even better. The 2 different colors are like seeing a picture from Dukesfest. There were always different orange GL's there. I'm going to stick with the Corvette Flame Red color for the next General Lee's I build. I'm planning on building LEE 1 and LEE 3 from "One Armed Bandits" using Revell '69 Charger kits. I also have a 1/16 General Lee kit I'll be building soon and a Ghost Of The General Lee kit. I can never have enough General Lees. Edited December 22, 2017 by Boss JD Hogg Quote Link to comment Share on other sites More sharing options...
HossC Posted December 22, 2017 Report Share Posted December 22, 2017 Great job (again). I don't think I've ever seen color comparisons done with models. Boss JD Hogg 1 Quote Link to comment Share on other sites More sharing options...
