Another 'Orange Clunker Car' - MPC Snap Kit General Lee - FINISHED
Posted (edited)
I started working on another General Lee model.  This is the 1/25 scale MPC Snap Kit General Lee.
I started by re-shaping the rear window.  It's basically a rectangle in the kit so I made it a bit larger and rounded at the top and also changed the angle to be a bit more steep.  I added missing window trim under the side windows and made the rear wheel openings slightly smaller in the rear.
The body is painted 1975 Corvette Flame Red which was the color most used on the General Lee(s) in the TV show.  The paint is from Gravity Colors.  The decals represent the early Georgia car which is my favorite look.  In a few days I'll spray the clear coat on the body.
I worked on the interior a bit.  I scratch built arm rests, pedals, window rollers, center console, head rests automatic shifter and a roll bar.    This kit comes with a stick shift but the General Lee was always shown on screen with an automatic.  I also modified the transmission on the chassis to resemble a 727 Torqueflite automatic.
The interior had an armrest molded into the center console which I removed.  I also added a strip of molding along the upper part of the door panels.
Much like the MPC glue kit General Lee, the dashboard sat too low and level.  I raised it up and angled it a bit.  The interior tub sat to low and too far forward when it was attached to the inside of the body.  I removed the mounting tabs and filed down the sides so it fits up to the top of the doors and moved back a bit.  I had to then move the dashboard forward.
The grill inserts in the kit are for a later year Charger, much like the MPC glue kit.  I scratch built new grill inserts using some ribbed styrene sheet.  The push bar is scratch built to resemble the early style push bar.
I'll get the parts in primer and start painting them.
Thanks for looking in!
37119715356_fc213c1166_o.jpgIMG_8605 Small by Michael Scarola, on Flickr37137331082_ff530a4298_o.jpgIMG_8606 Small by Michael Scarola, on Flickr37119715306_be1af4abed_o.jpgIMG_8609 Small by Michael Scarola, on Flickr37119714786_d43771cb62_o.jpgIMG_8633 Small by Michael Scarola, on Flickr37119715266_8bf1365e26_o.jpgIMG_8660 Small by Michael Scarola, on Flickr37119714756_767bdd206d_o.jpgIMG_8678 Small by Michael Scarola, on Flick37119714696_0dc1324023_o.jpgIMG_8683 Small by Michael Scarola, on Flickr37119715216_1480bd4329_o.jpgIMG_8692 B 30 C 10 Small by Michael Scarola, on Flickr37119714666_d2e49967a2_o.jpgIMG_8694 Small by Michael Scarola, on Flickr37119715156_6fcc74ebaf_o.jpgIMG_8696 Small by Michael Scarola, on Flickr37137330622_cde1239619_o.jpgIMG_8699 Small by Michael Scarola, on Flickr36912554500_f819095b9e_o.jpgIMG_8701 Small by Michael Scarola, on Flickr37119714446_f146516d41_o.jpgIMG_8711 Small by Michael Scarola, on Flickr37137330202_628a72da4a_o.jpgIMG_8712 Small by Michael Scarola, on Flickr37119714376_d658be38db_o.jpgIMG_8717 Small by Michael Scarola, on Flickr36912554420_0f24cb183c_o.jpgIMG_8723 Small by Michael Scarola, on Flickr37137330002_b87e463621_o.jpgIMG_8735 Small by Michael Scarola, on Flickr
Edited by Boss JD Hogg
Posted
Here's another update!
I painted the interior and used embossing powder for the carpeting. The interior is painted Tamiya XF-59 Desert Yellow. The dashboard and speaker tray are painted Testors Acryl Leather with a few drops of white added. The center console is painted to look like wood although it doesn't show too well in the pictures. I painted Testors Acryl Leather over Testors Flat White with some Radone Tan added. I used BMF(Bare Metal Foil) on the door handles and trim.
The chassis is done. Since it's a snap kit with molded in exhaust and drivetrain, I just painted it Testors Acryl Aircraft Interior Black. The Exhaust and drive shaft are brush painted with Citadel Leadbelcher. The engine oil pan is brush painted Testors International Orange and the transmission is Tamiya XF-16 Flat Aluminum. The gas tank was airbrushed with Tamiya XF-56 Metallic Grey.
The body was clear coated with Gunze Mr. Super Clear and polished.
I have to apply BMF to the moldings and install the windows.
37989685696_7c4e377b19_o.jpgIMG_8799 Small by Michael Scarola, on Flickr
38012085302_147c86b567_o.jpgIMG_8805 Small by Michael Scarola, on Flickr
38012085592_00bbbfcca7_o.jpgIMG_8808 Small by Michael Scarola, on Flickr
38012085802_a96a55d843_o.jpgIMG_8810 Small by Michael Scarola, on Flickr
38012087132_84075fe2cd_o.jpgIMG_8815 Small by Michael Scarola, on Flickr
38012089202_7b434dcbc7_o.jpgIMG_8816 Small by Michael Scarola, on Flickr
38012091342_22c95a1eb6_o.jpgIMG_8821 Small by Michael Scarola, on Flickr
38012091782_3dd707b756_o.jpgIMG_8822 Small by Michael Scarola, on Flickr
38012092242_38e2f31ea7_o.jpgIMG_8824 Small by Michael Scarola, on Flickr
38012092682_096a5cacc8_o.jpgIMG_8825 Small by Michael Scarola, on Flickr
38012093472_052a22428d_o.jpgIMG_8828 Small by Michael Scarola, on Flickr
Posted
:previous:
I'm guessing that when you're having to prepare roughly two cars for every show, any time-saving shortcuts help, so leave the small flags off.
Great work on the model, BTW. I was expecting a snap kit to be far less detailed, but that doesn't seem to stop you adding those details in.
Posted (edited)
Thanks Roger and Hoss for the kind words!
I read somewhere that they removed the 2 smaller flags to save time since they weren't seen all the time.  The early Georgia episode Generals are my favorite look for the car so I like to include them on my builds.
I'm not as crazy about how the General Lee had the light beige interior and the wider/flatter push bar in the later seasons so I tend to stick with the earlier look.
This snap kit is a new tooled kit from MPC but it's largely based on the original General Lee glue kit.  It does have a correct 1969 hood.  The original glue kit has a 1970 hood.  I added the same details to the interior that I added when I build the glue kit last year and scratch built the push bar too.  The General Lee parts(push bar, roll bar, CB radio, decals...) that come in the kit aren't too accurate so I made them and used decals a friend had made for me.
I didn't use the Vector wheels that came in this kit either.  I'm not sure why they didn't include the same wheels from the glue kit, which are far more accurate.  This kit's wheels are flatter then they should be.  I used a set of Vectors from an AMT 1969 Riviera kit that look more accurate.
I have to put the foil on the moldings and install the windows and I can put it all together.
Thanks again for looking in and the nice comments! :)
Posted (edited)
  On 11/23/2017 at 9:41 PM, Roth Potter said:
As always, great job on that model!
I didn't know there was a difference on the hood between those years. What is different?
Expand
Here's a picture showing the MPC General Lee's(1970) hood on the right side in white plastic and an MPC 1969 Charger hood in yellow plastic.
In 1968 and 1969 the 2 scoops in the hood were smaller.  In 1970 the 2 scoops were wider and differently shaped.
35400115013_de82afc884_o.jpgIMG_6094 Small by Michael Scarola, on Flickr
Posted
My mind is blown! I always though something was off on 70s Chargers. Guess I know what it is now.
I have an MPC kit as well. Bought it 3 years ago in a know museum in the UK. It seems to be a glue kit though as I just checked it out. It 100% has the hood thats on the right side of your picture! :blink:
I got the Police car as well as a Revell Charger. Can definitely see the difference in hood in the Revell and MPC chargers too.
Posted (edited)
From what I heard when MPC originally released the 1/25 General Lee they couldn't find the correct 1969 hood and interior bucket.  It was released with a 1970 hood and a stock car interior bucket.
When MPC released the Charger 500 kit they found the correct 1969 hood.  The 1969 hood tooling was misplaced again so the General Lee kept the 1970 hood.
38566676136_c43ef26e0a_o.jpg1969Charger500 by Michael Scarola, on Flickr
When I built my MPC glue kit General Lee I located a 1969 hood from a Charger 500.
Here's my MPC glue kit General Lee I built last year with the 1969 hood and correct interior.35813594630_b443f24c94_o.jpgIMG_7579 Small by Michael Scarola, on Flickr
  • 4 weeks later...
Posted
I finished the General Lee.  Here are some pictures.
27405462959_a755a845ea_o.jpgIMG_9080 Small by Michael Scarola, on Flickr
24322179507_874e28b18b_o.jpgIMG_9082 Small by Michael Scarola, on Flickr
27405463099_9865a31d33_o.jpgIMG_9068 Small by Michael Scarola, on Flickr
27405462899_41e01c4505_o.jpgIMG_9084 Small by Michael Scarola, on Flickr
27405462819_57937be260_o.jpgIMG_9089 Small by Michael Scarola, on Flickr
24322179377_e3fed3e703_o.jpgIMG_9072 Small by Michael Scarola, on Flickr
24322179547_e6292f0193_o.jpgIMG_9073 Small by Michael Scarola, on Flickr
27405463039_c00edb9993_o.jpgIMG_9077 Small by Michael Scarola, on Flickr
38306471945_2c24e45922_o.jpgIMG_9078 Small by Michael Scarola, on Flickr
24322179127_fabb0c2d03_o.jpgIMG_9090 Small by Michael Scarola, on Flickr
27405462769_d849764e86_o.jpgIMG_9093 Small by Michael Scarola, on Flickr
24322179057_5c9d9ea723_o.jpgIMG_9095 Small by Michael Scarola, on Flickr
Posted (edited)
Here are some pictures I took with both General Lees I built.  The lighter orange GL is this one I just finished and the darker orange GL is the one I built last year.
This new one is painted 1975 Corvette Flame Red which was the main color used on the beauty cars on the show. The last one I built is Chevrolet Hugger Orange which is a darker, more red, looking orange.
38312550935_2d3019c4a5_o.jpgIMG_9098 Small by Michael Scarola, on Flickr
39188706671_873c55ee9e_o.jpgIMG_9100 Small by Michael Scarola, on Flickr
38312550985_8661d5788a_o.jpgIMG_9105 Small by Michael Scarola, on Flickr
Posted
You could do an episode of "Double Dukes" since they had two. "Dukes Meet Cale Yarborough" had three. I probably wouldn't have even noticed the color difference if you wouldn't have mentioned it. I probably would have thought it was just the lighting. Once again, excellent works of art!
Posted (edited)
Thanks again Roger!
"Dukes Meet Cale Yarborough" is one of my favorite episodes.  I remember back when I first saw it I thought the white Charger was so cool and then the 3 General Lees at the end was even better.
The 2 different colors are like seeing a picture from Dukesfest.  There were always different orange GL's there.
I'm going to stick with the Corvette Flame Red color for the next General Lee's I build.  I'm planning on building LEE 1 and LEE 3 from "One Armed Bandits" using Revell '69 Charger kits.  I also have a 1/16 General Lee kit I'll be building soon and a Ghost Of The General Lee kit.  I can never have enough General Lees.
