Andrew D Charger Chaser Posted February 26, 2021 Author Posted February 26, 2021 In the episode "Daisy's Close Call" (S6 E19) Cooter is seen using a tool box from the rig. I can't see it in any other episode, so, being Hollywood, it probably wasn't there at any other time, not being a true "working" rig. Still, I thought it would be a great, even necessary, addition. I estimated the size at about 20" x 8" (when he carries it to the truck it is indeed fairly slender). From some angles the grime from being handled by a mechanic is visible. Appears to have a silver or light colored handle. I scratchbuilt it in an evening, primed it and painted it the next day. The same day I scratchbuilt a crowbar, and added a hammer and a wrench that came with the two junkers from which this project began. The wrench was finished in Alclad stainless steel, then grime strategically added. All the tools were made to appear worn and heavily used. Finally all this was added to the wrecker bed, including an extra length of chain visible in the episode "Happy Birthday General Lee". Hobie Hartkins, MoonRunner-01, Andrea Como and 1 other 4 Quote
Spike Posted February 26, 2021 Posted February 26, 2021 Just...wow. the level of detail. RogerDuke 1 Quote
HossC Posted February 26, 2021 Posted February 26, 2021 2 hours ago, Andrew D Charger Chaser said: I scratchbuilt it in an evening, primed it and painted it the next day. You make it sound so easy. This would be an impressive build if it was all shiny, but the weathering and dirt take it to another level. I can't believe that you even used different guitar strings for the aerials - that's attention to detail! RogerDuke and Hobie Hartkins 2 Quote
Hobie Hartkins Posted February 26, 2021 Posted February 26, 2021 THAT...is just unbelievable!! EEEEEXCELLENT! RogerDuke 1 Quote
Andrew D Charger Chaser Posted February 26, 2021 Author Posted February 26, 2021 Y'all are amazingly kind with your comments! Also, I forgot to mention the dually wheels are resin items I got on Ebay which match exactly the ones on the real thing. RogerDuke and Hobie Hartkins 2 Quote
RogerDuke Posted February 27, 2021 Posted February 27, 2021 3 hours ago, Andrew D Charger Chaser said: Y'all are amazingly kind with your comments! It's easy to make a comment. What you're doing is hard....and quite impressive. Spike and Hobie Hartkins 2 Quote
Hobie Hartkins Posted February 27, 2021 Posted February 27, 2021 39 minutes ago, RogerDuke said: It's easy to make a comment. What you're doing is hard....and quite impressive. exactly! That's a lot more patience and skill than I would ever have! RogerDuke 1 Quote
Andrew D Charger Chaser Posted February 27, 2021 Author Posted February 27, 2021 Okay, finally time for the COMPLETED item, my Ultimate Cooter's GMC Tow Truck! Only complaint is the decals on the door are 'way too oversized, but they were the only ones I've been able to find in years of looking. RogerDuke, Hobie Hartkins, Spike and 1 other 3 1 Quote
tim legg Posted April 7, 2023 Posted April 7, 2023 On 2/22/2021 at 11:38 PM, Andrew D Charger Chaser said: On to the actual tow cable. I was first referred to some braided metal cable produced specifically for modelmakers, but it was much too thick, and didn't coil around the spool at all. I found my answer in a picture hanging kit. The braided wire for hanging pictures on a wall was almost perfect in the smallest size, the 10-50 lb strength. I ran it through a candle flame to give it the appropriate worn/stained appearance. Next, some of the most critical scratchbuilding of the project, the sling. I tried various materials to simulate the heavy duty rubber straps, including black duct tape, black latex gloves and even bicycle inner tube. The latter had the perfect appearance but alas, was far too thick. I found the answer in black party balloons. The rounded part had too many curves to use, but the balloon necks had barely enough length of flat material. Add to that the chains on each side and the effect exceeded my hopes. On the end of the chains are hooks; these I made from reshaped sections of paperclip, then attached to the chains and painted worn dark metallic. After this I was VERY relieved and pleased with the result. Am new to the group but your tow trucks got me building one just like yours few things r a little different not much but i have alot of questions like how cable above the booms hows it hook in to at the top of the booms RogerDuke 1 Quote
RogerDuke Posted April 7, 2023 Posted April 7, 2023 On 2/27/2021 at 10:55 AM, Andrew D Charger Chaser said: Okay, finally time for the COMPLETED item, my Ultimate Cooter's GMC Tow Truck! Only complaint is the decals on the door are 'way too oversized, but they were the only ones I've been able to find in years of looking. I don't remember seeing this when it came out 2 years ago. It is amazing! Quote
RogerDuke Posted April 7, 2023 Posted April 7, 2023 14 hours ago, tim legg said: Am new to the group but your tow trucks got me building one just like yours few things r a little different not much but i have alot of questions like how cable above the booms hows it hook in to at the top of the booms Welcome to the HazzardNet Tim. I hope Andrew noticed your post and responds. Is Cooter your favorite character? How long have you been a Dukes fan? Quote
Hobie Hartkins Posted April 7, 2023 Posted April 7, 2023 On 2/27/2021 at 9:55 AM, Andrew D Charger Chaser said: Okay, finally time for the COMPLETED item, my Ultimate Cooter's GMC Tow Truck! Only complaint is the decals on the door are 'way too oversized, but they were the only ones I've been able to find in years of looking. This is fan tastic!! This is also my favorite Cooter Tow truck! You did a great job! ( Come on by the car lot and I'll slip you some of my fines!......hurry though....I'm drinking right now! { can I say that here....I didn't look to see if I was in the adult section! } ) RogerDuke 1 Quote
RogerDuke Posted April 9, 2023 Posted April 9, 2023 On 4/7/2023 at 5:24 PM, Hobie Hartkins said: This is fan tastic!! This is also my favorite Cooter Tow truck! You did a great job! ( Come on by the car lot and I'll slip you some of my fines!......hurry though....I'm drinking right now! { can I say that here....I didn't look to see if I was in the adult section! } ) It's hard to believe it's not a real tow truck. Quote
Hobie Hartkins Posted April 9, 2023 Posted April 9, 2023 15 hours ago, RogerDuke said: It's hard to believe it's not a real tow truck. You got that right! Every little detail...!!! Mighty impressive! RogerDuke 1 Quote
