My Ultimate General Lee build in 1/25
Andrew D Charger Chaser
Photos to be posted soon. I wanted to put everything I could into the ultimate build, and this one took me about three years of on-and-off work. Seriously.
MY G.L. BUILD PHILOSOPHY
My main criticism of most GL builds is that they are 'way too immaculate to be an in-use back-roads racing car driven by good-ol-boys on a farm. They always look...well, sterilized comes to mind. Absolutely gorgeous, like they're going for the trophy at a car show, with a car that's never driven except on and off a trailer. Not this one!!
-Interior: Agree with many that the darker brown "saddle" color of the earlier series looks better, but a darker interior will hide most great detail. So, cliche though it is, I went with the light tan. HOWEVER I weathered it plenty, with very stained floor carpeting, and some wear on the seats. Scratchbuilt items are a CB radio and a detailed, padded-looking roll bar with tape around the padding.
-Engine Bay: Despite most builds painting the engine bay interior orange, indicating a total engine-out restoration, the actual "Hero" Generals had their engine bays hastily painted black around the engine. This would also fit with the storyline of the original color being black.
Additionally, I sanded out all the molded on wiring and scratchbuilt the entire engine wiring and detail. When you see these photos you may be shocked. I know I am....not eager to do this again, although it was worth it!!
-Underside: Dark primer gray with orange overspray indicating a home-done paint job. Lots wear and some general rusting, with a ton of dust and dirt oversprayed.
So much more involved in this build, but those are some of the basic philosophies I followed on this.
Link to comment
Share on other sites
Thanks!
Here, the windshield and other window glass has been tinted with future and food coloring:
Scratchbuilt Roll Bar has been made to look like it's padded with tape holding on the padding:
And, the interior, including Photoetched steering wheel spokes, scratchbult CB radio, heavily stained flocking for carpeting:
Link to comment
11 hours ago, HossC said:
You have a great eye for detail, Andrew. I'm looking forward to seeing this build progress.
Any chance you could change your text color in the post above? - it's almost impossible to read (for me anyway).
Thanks Hoss!
Unfortunately I'm not able to go back and edit posts once I log out and come back...not sure if that's just me or the way the boards are set up....
Link to comment
Next batch here. Soaked all the bumper/grill bits in bleach to remove the chrome. Cleaned up the imperfections on both, and removed the grill from its surround. Used the same passenger-side grill section from another kit to use on the left side since no Charger emblem should be there. Refinished with Alclad II on the bumpers and trim, flat aluminum on the grill tunnels, lots of drybrushing etc on the grill once sprayed flat black, and semigloss on the middle sections where the non-headlight sections are. Scratchbuilt narrow-style push bar.
Edited by Andrew D Charger Chaser
Link to comment
Thanks Roger!
Here's the chassis, suspension and exhaust, weathered with wear 'n' tear, and even some rust at appropriate places. Much of it will be covered/disguised by the road dust to be sprayed on last. Once installed, the edges received some orange overspray, indicating a home-done paint job.
The wheel hubs are from the old MPC General Lee kit. Chrome removed with bleach, then heavily sanded on the rear until the five openings were actually opened as they should be. Then primed, sprayed flat black, and detailed with aluminum paint. Not chrome. Those bits are shiny, but not quite chrome, with the possible exception of the lug nuts.Tires sanded with fine sandpaper and fine steel wool to remove the shiny vinyl "toy" look.
And, even the CB antenna; scratchbuilt styrene base, with a bit of High "E" metal guitar string.
Link to comment
