Andrew D Charger Chaser Posted March 24, 2020 Posted March 24, 2020 For those who didn't know, the Charger wreck used in Episode 4 "Repo Men" was the same car that made the jump at the very end of the show's opening credits. LOVED this car the first time I saw it as a kid, did not know how important it was until decades later. Replicating this wreck in 1/25 will be a VERY ambitious project. CHARGER UK 1 Quote
Andrew D Charger Chaser Posted March 24, 2020 Author Posted March 24, 2020 If I can't replicate the body damage, the entire project is pointless. If I only heat up and bend the plastic body it will look toylike, as the body thickness when scaled up would be akin to a couple inches thick. Not convincing at all. THE SOLUTION: Make aluminum foil copies of the body sections to be damaged. Let's try it on the hood first: Quote
Andrew D Charger Chaser Posted March 25, 2020 Author Posted March 25, 2020 Once damaged to taste, the foil is filled from behind with tons of gap-filling superglue and plastic strip reinforcements. Then to the body itself, the same treatment but MUCH bigger. LOTS of superglue to fill it all from behind. Then priming and sanding in appropriate areas. CHARGER UK and Flint Duke 2 Quote
Andrew D Charger Chaser Posted March 25, 2020 Author Posted March 25, 2020 The interior needs special work. From what I can see in the episode, the interior panels under the rear windows were removed along with the back seat, although I've read that only the seat was removed to install the full roll cage. So, I had to remove the rear panel and totally rebuild it as the interior structure that the panel would normally cover. Was a 2 full day scratchbuilding job, daunting at first but well worth it in the end. The carpet will be well worn and stained soon. CHARGER UK and Flint Duke 2 Quote
Flint Duke Posted March 25, 2020 Posted March 25, 2020 The detail you do on these is just sick ! Great work ! Quote
Andrew D Charger Chaser Posted March 25, 2020 Author Posted March 25, 2020 Thank you Flint, I appreciate it! Quote
HossC Posted March 25, 2020 Posted March 25, 2020 It took me a while to see where you were going with all that hole cutting, but the finished article makes perfect sense. Great work as usual. I look forward to seeing this build develop. Quote
RogerDuke Posted March 25, 2020 Posted March 25, 2020 (edited) This leaves me speechless. We are in the midst of greatness. You have the hands of a surgeon, the skills of a master craftsman and the passion for Hazzard of a genuine Duke boy. I'm calling my best friend and telling him he's been replaced. What a super fan! Thanks for sharing this and it will fun be fun to see it evolve. Edited March 25, 2020 by RogerDuke Flint Duke 1 Quote
Andrew D Charger Chaser Posted March 27, 2020 Author Posted March 27, 2020 Roger, I am very moved and humbled by your words....speechless, even. I can only offer my sincerest thanks and appreciation! RogerDuke 1 Quote
Andrew D Charger Chaser Posted March 27, 2020 Author Posted March 27, 2020 I've never taken as much trouble as this for the accurate steering wheel, but here's what I finally accomplished: CHARGER UK, RogerDuke and Flint Duke 3 Quote
Andrew D Charger Chaser Posted March 29, 2020 Author Posted March 29, 2020 ROLL CAGE Tip: Do NOT use the roll cage from the MPC "General Lee" for this project. Wrong style, wrong design, wrong size. I also found some drawings online which purport to be the actual design sketches for the original. They do match what I see in all the photos. CHARGER UK and Flint Duke 2 Quote
Andrew D Charger Chaser Posted March 29, 2020 Author Posted March 29, 2020 Here's how the scratchbuilding went, using 1/16" rod for the frame and tubing fitted over the rod for the padded sections around the driver's side: CHARGER UK 1 Quote
Andrew D Charger Chaser Posted March 29, 2020 Author Posted March 29, 2020 (edited) Finished roll cage: Edited March 29, 2020 by Andrew D Charger Chaser Flint Duke 1 Quote
RogerDuke Posted March 29, 2020 Posted March 29, 2020 Cool stuff. It was neat to see that it was displayed at a car show. Is that a reflection of you above Cooter? Quote
Andrew D Charger Chaser Posted March 29, 2020 Author Posted March 29, 2020 LOL yep...I'm still too low-tech to be able to do screen-grabs from the TV. I'm sure the capability is there in what I've got, but just need to be shown how to use it. More importantly, I need to care enough to upgrade....but I just do what works for what I need. Quote
RogerDuke Posted March 30, 2020 Posted March 30, 2020 You actually look a little like me.....not really sure since it wasn't a great picture. Contrary to popular belief I don't look like Uncle Jesse...even though I hope to someday. Quote
Andrew D Charger Chaser Posted March 30, 2020 Author Posted March 30, 2020 I could've lied and either said no, it was really me in the General ...or, that faint image is really the Ghost of General Lee RogerDuke 1 Quote
Andrew D Charger Chaser Posted April 1, 2020 Author Posted April 1, 2020 FRONT BUMPER Need the front bumper to look like bent metal, and not a bent plastic model part. Made an aluminum foil cast of the central section; removed that plastic, attached the ends to the foil cast. Very carefully bent and dented it to match the photos. Filled with CA glue with wire reinforements for the structure. Primed, will be coated with Alclad chrome tomorrow or Thursday. RogerDuke 1 Quote
Andrew D Charger Chaser Posted April 1, 2020 Author Posted April 1, 2020 Final bodywork touchups and priming, and ready for paint. Tough to match the exact color, since in the episode (the way I'm making it) it was disguised/obscured with gray scratchwork all over it, and the recovered wreck was apparently quite weathered and faded. Did the best I could. Finally settled on a mix of 5 different blues and greens. It's actually darker than the photos show.... I settled on: 2 parts Testors Gloss Dark Blue (#1111); 2 parts Testors Dark Beret Green; 1 part Model Master Dark Sea Blue; 1 part Testors Gloss Green; 1 part Gloss Light Blue. RogerDuke 1 Quote
Flint Duke Posted April 1, 2020 Posted April 1, 2020 Your really hammering this one out quick ! Looks AWESOME ! RogerDuke 1 Quote
RogerDuke Posted April 1, 2020 Posted April 1, 2020 It's pretty cool to watch unfold before our very eyes. I'm sure you're right about being tough to match the paint up but if anybody can do it it's you. You're our Arte Bender. Quote
HossC Posted April 5, 2020 Posted April 5, 2020 I think I'd find it tough to deliberately add damage to such a pristine paint job, but as usual, you nailed it! RogerDuke 1 Quote
