July 4, 20251 yr It has been years since I've seen the show and would like to get the dvds, but I'm worried because Dukes Of Hazzard is on the list of dvds affected by Warner Bros. disc rot. Does anyone know if this is true ? Which complete series set should I try for ?
July 4, 20251 yr Mine are fine, but I bought them in the UK/Ireland, so the pressing may be different. I also ripped all of mine to a backup drive just in case. You may as well start with season 1, although it's the shortest wirh only has 13 episodes.
July 4, 20251 yr Author 21 minutes ago, HossC said: Mine are fine, but I bought them in the UK/Ireland, so the pressing may be different. I also ripped all of mine to a backup drive just in case. You may as well start with season 1, although it's the shortest wirh only has 13 episodes. So I should go with the individual seasons ?
July 4, 20251 yr If you can get a deal on a box set, go for it. I'm guessing that you're in the US, so maybe someone else here can tell you the best place to look. I think another member got a good deal a Walmart recently. I checked their website, and they're doing the complete TV series (7 seasons) for under $50 and the two TV movies for under $10. I don't live in the US, so I don't know if there are better deals and better retailers to use.
July 4, 20251 yr 2 hours ago, Spottedfeather said: It has been years since I've seen the show and would like to get the dvds, but I'm worried because Dukes Of Hazzard is on the list of dvds affected by Warner Bros. disc rot. Does anyone know if this is true ? Which complete series set should I try for ? I think this only affects earlier pressings, 2006-2008. Anything manufactured after 2008 should be fine. That said, I think Warner Bros has said they would replace them. https://nypost.com/2025/03/13/tech/your-old-dvds-are-suffering-disc-rot-warner-bros-will-replace-them/
August 12, 20251 yr Author On 7/4/2025 at 1:13 PM, HossC said: If you can get a deal on a box set, go for it. I'm guessing that you're in the US, so maybe someone else here can tell you the best place to look. I think another member got a good deal a Walmart recently. I checked their website, and they're doing the complete TV series (7 seasons) for under $50 and the two TV movies for under $10. I don't live in the US, so I don't know if there are better deals and better retailers to use. I've seen different versions of the complete series. Do they all have the tv reunion movies ? I've seen some that appear to have the two remake movies with johnny knoxville.
August 12, 20251 yr 50 minutes ago, Spottedfeather said: I've seen different versions of the complete series. Do they all have the tv reunion movies ? I've seen some that appear to have the two remake movies with johnny knoxville. Not that I've seen. Reunion 1997 and Hazzard in Hollywood 2000 with the original cast come separate in The Dukes of Hazzard 2 Movie Collection. Reunion on one disc, Hazzard in Hollywood on the other disc. 2 disc set. Each original cast movie has a DVD all its own.
August 12, 20251 yr Author 3 minutes ago, Skipper Duke said: Not that I've seen. Reunion 1997 and Hazzard in Hollywood 2000 with the original cast come separate in The Dukes of Hazzard 2 Movie Collection. Reunion on one disc, Hazzard in Hollywood on the other disc. 2 disc set. Each original cast movie has a DVD all its own. that sucks, then. because the only dvd of the tv movies is from 2008, which could possibly have disc rot.
