What kind of driver are you?
43 members have voted
  1. 1. What kind of driver are you?
    • Shotgun(Front Seat Passenger)
    • Wingman(Rear drivers side)
    • Backseat(Rear Passenger Side)
      0
1. Which of the following is not the responsibility of the Back Seat Driver?
A.Regulating the Temperature of the Rear Cabin.
B. Assisting The Driver In Merging
C. Radio Station Selection
2. The Driver has just initiated a parrelled parking maneuver. You should:
A. Turn Around and Offer Your Opinion on Much Space The Driver Has To Back Up.
B. Move Your Body In a 45 degree angle to provide a clear view for the driver.
C. Lower Your Headrest To Reduce Obstructions.
3. The Proper Seating Position for the Backseat driver Is:
A. The Front Passenger Seat
B. The Rear Driver Driver Side Seat
C. The Reat Passenger Side Set
4. When Backseat driving under the influence of alcohol, you should always :
A.Place Your Beverage securely in the nearest cupholder
B. Use the Restroom frquently
C. Never Backseat drive under the influence of Alcohol
5. What assisting the driver in Parellel parking, the backseat driver, the backseat driver:
A.S hould always remain seated.
B. Stand Outside the Vehicle and aid in the driver in avoiding the collision with parked vehicles.
C.Lean Forward Into the Front Seat
6. When Parrellel parking, the backseat driver should use all but one of the following methods to approximate the amount of distance remaining between vehicles:
A. The Wave and Stop
B. Sign Language
C. Holding Your Hands Apart in a Rough Estimate
7. Which of the following beverages will results in the fewest numbers of pit-stops?
A. 32 oz soft drink
B. 64 oz Coffee
C. 12 oz Soft drink
The Answers 1. C 2. B 3. C 4. C 5. B 6.B 7.C
Correct Answers Result
Seven Pass
Five-Six Pass(However Further Studying couldn't hurt).
three-Four Fail
one-two Fail(Did You even read the manuel.)
