swinks Posted December 8, 2014 Posted December 8, 2014 After I found the graphic the other day with the dimensions I created the cad graphic yesterday and thought it would be cool to design a themed General Lee "01" Dress / Driver ring just for fun.As a past time I enjoy 3d designing and mainly do pinball parts to help friends out as parts are no discontinued for many of the pins that are 20 or more years older.This ring is approx 7mm wide in the band and 1.5mm thick so not too chunky and uncomfortable with a slight taper to the outer edges for a more comfy fit. On the top is my interpretation of a V8 motor cylinder which is 16mm round with a slight domed top with 01 recessed in. I did an artistic interpretation of what you could do but painting in the centre with Dukes of Hazzard "orange" of the ring and wiping off the excess to make the ring pop even more. I opened up lots of choice of materials as well as 2 plastic version that you can always print and check for fit and then get the metal one that you really want once you know the right size.This one is a size 13 (22.2mm) to suit my fat finger but if you would like a particular size just let me know.https://www.shapeways.com/model/2934339/general-lee-quot-01-quot-driver-ring-size-22-2mm-id.html?li=aeTabsHave Fun. Quote
swinks Posted December 8, 2014 Author Posted December 8, 2014 added a Mopar Ring as wellhttps://www.shapeways.com/model/2934578/mopar-driver-ring-size-22-2mm-id.html Quote
